cp2295
- Jul 25, 2013
- Reaction score
- 7
- Location
- Washougal, wa
- Make / Model
- Ford
- Engine Size
- 4.0L swap, 8.8 explorer axle, IFS front end
- Manual
- My credo
- If you ain't first you're last
Hi I have a 98 4.0 ohv, I found out a few months ago the #4 injector was leaking so I replaced it with a standard motor products injector. My issue was hard starting while hot. After putting in the new injector it still would have a hard time starting when hot, but I gave up and today I decided to investigate. I pulled all the plugs out and every cylinder was clean (no fuel in it) except the #4 again. I put it in clear flooded mode and had my dad look at 1 bank at a time, and sure enough #4 sprayed fuel out. Plus the plug was gunked up with carbon. All the other plugs are immaculate.
So I'm thinking now it could be a wiring issue or something, maybe it's being held open? Or maybe I got a defective part. Anyone got any ideas?
