A4ld to fm145 or 146, advice needed
The_Dealer
10
Macon, GA
Duh!
well im getting tired of my a4ld not doing the right thing so i come to the conclusion that its time to swap it out for a manual trans. ive been looking in my area for different transmissions to swap in, and ive found a fm145/manual tcase, and a fm146 without t-case. im wondering which would be the easiest to swap in place of my a4ld? will i have to get the donor cars crossmember or can i use the one i have now(bushingless, mounts to the frame)? also which would be the better one to use so i dont have to change out my driveshafts?
the fm145 is closer to me and its cheaper, even though it includes the transfer case
any opinoins on which one to get? i seem to have found everything else i need for the swap
baddis
Solid Axle Swap
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
find an m5od. they are the same length as the a4helld
baddis
Solid Axle Swap
6
Avon,il
2014
check with allen d i know he usually has some ready to go and he will ship them. if you were closer i would sell mine as i am going to do a v8 swap but i have no way to ship it.
The_Dealer
10
Macon, GA
Duh!
well i just found one from a b2 for 500 and its right down the road, im trying to go the cheapest route as i only have about 700 im willing to drop on it at this time, but one of the fm146's i found i can get the clutch line, flywheel, m/c, and slave cyl for around 500, then another 50 for the pedal assembly
EDIT: hell i could get another a4ld for 350 and then id have money for other mods but im scared im going to run into the same problem, this is my dd and i have a baby on the way, wont b able to afford a new tranny every month after he gets here
baddis
Solid Axle Swap
6
Avon,il
2014
i got everything i needed to swap the m5od for $200 by purchasing a totaled truck and doing it myself.
necessaryevil
salem,or.
ford
2.9
if i remember right the fm145 came out of a '83-'87 and the fm146 came out of a '88-'91 and there is a difference, the 145 is a bit longer and the shifter is further back on the trans compared to the 146
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
You got that backwards evil. The 146 is longer, same length as the A4LD, and it's easier to switch to from the A4.
necessaryevil
salem,or.
ford
2.9
i knew one of them was longer, making the cross member mounts different, and the axles different length
tmar04
bronco II
don't mean to hijack thread, but I am getting ready to swap 5 spd Toyo Kogyo from 84 B2 to 87 b2 with A4ld. do you guys see any problems with this swap? thanks so much.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I think you mean drive shafts.
A4LD to 146 shouldn't be a problem.
The_Dealer
10
Macon, GA
Duh!
all right well i called the j/y with the fm146 and they give a 30day warranty, and they have the pedal assembly and line, any reccomendations for a brand of flywheel and clutch kit?
birddog321
18
Buford, GA
2.9
Check Craigslist, I saw alot of parts for Rangers and B2's the other day
The_Dealer
10
Macon, GA
Duh!
thanks, ive read alot about different trans needing a pilot bearing adapter, will i need one for the fm146?
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
