Battery light coming on
WhiteLX
So Cal
2.9L
This is a problem I have had for probably the last year. i can't seem to figure out what is causing it. The truck is an 89 with the 2.9L V6.
The battery light on the gauge cluster is coming on. Sometimes it's constantly on, sometimes after driving for a long time it goes out, but most of the time it's flickering. I took the truck to autozone to have them test the charging and electrical system. Their Autometer brand tester said the battery was bad. Odd, the truck never has a problem starting and prior to the test the light had been coming on for several months.
I dismissed their diagnosis and continued to drive the truck. Several months passed and one day the truck didn't start after a short drive to pick up some food. I took at look at the cables, wiggled them a little, and it fired back up.
I decided I should probably replace the battery. It was an old Optima redtop that had been in my Mustang for a few years and then in my ranger for a few more years. I replaced the battery, cleaned the terminals, and nothing changed. I added some additional engine to chassis grounds, nothing changed.
The only things I haven't done are replace the battery to engine cable and test the alternator off the truck.
Spott
TRS Banner 2012-2015
21
SE Idaho
Engine Type
2WD / 4WD
The wire running from the warning lamp to the alternator, might be grounding out somewhere. That would cause the lamp to light intermittently. Follow the wire and see if it has any bare spots.
Another possibility: test the resistance on the positive battery cable, while wiggling it (unhook it from the battery first). You might have a loose or intermittent connection.
Spott
1996DANGERRANGER
eaton township ohio
ford ranger
4.0
mine does it too. . but mine does it becasue the clip for the sesor wire on the alternator itself is broken so it wiggles loose. if i pullit off it comes on all the time. if i put it on tight it nevers comes on
WhiteLX
So Cal
2.9L
It's been a few years, but I finally found the problem, or at least I think I have. I won't know till I get it back together. One of the spade terminals on the alternator rectifier broke off in the connector. I noticed it when I pulled the alternator to get more room to change the spark plugs and tighten the valve cover bolts. It must have been making an intermittent connection which caused the light to flicker.
Perfect time to upgrade to a 3G alternator as I have been wanting to install an electric fan.
kimcrwbr1
46
maplevalley WA
ford
2.8l
This made me smile just for future reference there is a reason it is called a idiot light. When the light comes on you should find out why as quick as possible. You flat got lucky it didnt leave you stranded somewhere. First thing you need to do after you get it back together is do the load/ noload test on the charging system. If you want to keep an eye on the system just put a volt meter that tells you battery voltage with the ignition on. If the idiot light comes on do not just keep driving it find out why!
WhiteLX
So Cal
2.9L
excuse me?
Maybe it wasn't clear, but a load/no load test had been performed. It passed. The truck has a voltage meter, if there was a problem with the alternator failing and the truck running off battery voltage, I would have known.
It's called an idiot light because they don't provide any information when illuminated. I attempted to find out why when it initially came on, there was nothing that stood out and the truck continued to operate as normal for more than 3 years.
Maybe you should consider reading through your post and the thread a couple times to confirm your thoughts before hitting submit.
kimcrwbr1
46
maplevalley WA
ford
2.8l
Maybe in another thread you mentioned the volt meter and load/noload test I was just going by the black parts of your post. I still havent learned how to read the white parts.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
excuse me?
You are correct WhiteLX.
And thanks for the heads up about checking connectors and pins closer
kimcrwbr1's post was out of line and even worse, no help in this case, which is odd he usually has good info
kimcrwbr1
46
maplevalley WA
ford
2.8l
This is BS the first time the noload/load test was mentioned in this thread or the volt meter was when I did to help him. I care alot more about motors than your sensativity. I am sorry I hurt your feelings.
WhiteLX
So Cal
2.9L
Again with the reading comprehension and attitude. You even quoted it, but you can't seem to understand it. I'm not even going to bother pointing out the load/no load test, because you'll find some way to discredit it.
I didn't have to follow up to this post. I could have just let it die and be of no help to the next person. But as a benefit to the community, I responded with my findings.
RonD
Official TRS AI
8,370
canada
And we appreciate it :icon_thumby:
Staff online
Shran
April Truck of The Month
