Starter Issues
rojerts
So I'm on vacation and my starter goes out in my 89 B2, stock 2.9 EFI V6. Fortunately, I was on a hill so I could pop the clutch, after which I made my way to the nearest auto mechanic shop around for 50 miles.
The guy orders the new starter, and it looks like I'm home free. Then I get a phone call: "Your starter doesn't match the starter that the parts company sent me. The wiring is different (the old one has an extra wire), and the bolt pattern and bell housing are different from the starters in every other b2 or ranger out there, +/- a year."
Has anyone else had this issue? Did Ford install different starters?
Any ideas would be appreciated--especially because I need to get home by July 3rd (this Saturday) or my wife is gonna kill me!
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Pics would help.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
This info is from memory, and I'm getting old, so do more research. Ford did make different noses for manual vs auto, and how they clocked the 'solenoid'. You might be able to use the nose off the old one on the new body.
Richard
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
I've got 2 90 B2's, one auto and one manual. The starters interchanged. The auto one is an early 90 model, so its more like an 89. I even used a starter from an 88 on it.
More than likely they are trying to sell u a 4.0 starter. Its smaller than a 2.9 starter. Since the flywheels are different on a 2.9 and a 4.0, that might be the difference.
Like I said, pics would help
Beef52751
13
Eastern Iowa
could you pop start it again and haul ass home without shuting it off???
The old one has an extra wire?!? The 2.9 starters (or at least the ones that I've dealt with) only had 1 wire.
necessaryevil
salem,or.
i think they just sent the wrong starter, i had a 84 crown vic 5.0; that used the same starter as my 87' b2 and a buddys 89 b2
rojerts
I appreciate all the responses. Unfortunately, getting pics will be hard being in the middle of nowhere without a digital camera. But I'll try.
To answer Beef: I plan on popping the clutch and heading home without shutting it off, if this can't be solved by the mechanic. But, it's an 8.5 hour trip--so it would be nice to avoid that scenario.
I'll try to get some pics, and post them.
Ranger Kip
10
Wellsboro, PA
Ford Fleet
3.slow
Confused and Intolerant
Universals! Now I can pick apart a police car in town for parts! :icon_rofl::icon_rofl::icon_rofl:
SquashMan2009
Sudbury Ontario
Sounds like a 4.0L starter too me, i just swapped from a 2.9 to 4.0 and remember having what you described, bronco II starter will work as well.
I thought about this recently when smokeater was having start issues. I was going to send him my old 2.9 starter. The problem is that that only works one way, the 5.0 starter will work on a 2.9, a 2.9 starter won't start a 5.0.
rojerts
Well, the mechanic figured it out. He used a starter off a 92 Ranger, which was identical to the broken starter. I'm the fourth owner, and wonder if the first or second put in a newer 2.9 from a ranger. I'll have to check the VINs between motor and dash to see if they match up.
Thanks for everyone's help!
That could explain things.
