Fuel pump in gas tank problems.
marx
The fuel pump in tank work then doesn't some time starting and driving. Pump was change still the same problem. Is there a Relay or something that control the fuel pump. It like there power to pump and then nothing. please help.
Mark
8,369
Yes there is a Fuel Pump relay.
On an '88 it should be on the passenger side inner fender just off center towards the cab.
It will have a Green Base/Plug.
There will be another relay near it with Brown base/plug, that is the EEC relay it powers computer, spark and injectors.
Intermittent fuel pump is often that relay, and it is worth replacing, it is just a standard automotive relay, nothing special or expensive.
You can manually operate the fuel pump relay to test if that is the problem.
Look at the second drawing on this page: http://www.therangerstation.com/tech_library/OBD_I.shtml
That is a drawing of the Computer test port found near the firewall on drivers side, but have found it on passenger side as well.
Find that connector.
The slot labelled Fuel Pump in that drawing is the Ground for the fuel pump relay.
You can hook a jumper wire from that slot to a Ground.
If key is ON then relay should click closed and fuel pump should start and stay running if that jumper is in place.
In the relay plug/socket there should be a #30 and #87, if you put a jumper across these 2 slots the fuel pump should come on, key on or off won't matter, #30 is 12v from battery, and #87 is hot wire to fuel pump.
Picture of relay pins/slots here: http://dodgeram.org/tech/gas/Trouble/Fault-42.htm
Ford, dodge, chevy, ect..... doesn't matter they all use the same standard relays
ranger nation
california
97 ranger 4x4
86 bll
stop, dont screw it up yourself, let me do it
as an added bonus you now have a anti-theft device for free (after the cost of your relay ) if you leave your truck parked for any length of time, simply pop that relay out on toss it in your tool box, and they can crank till the cows come home, but your truck aint moving:yahoo:
marx
Its a 86 Bronco II with 2.9 will be same as the 88?
8,369
Yes, should be the same.
I think they moved the relays to under the "Power Box" in '89 or '90
'86 BII may have 2 fuel pumps, if so check the wire splice for the high pressure pump in the fuel rail under the drivers seat area, they tapped the power for that pump there and that splice has been known to fail.
