where to run the co ax cable?
86MUDRCJ
8
Sheridan, CA
2.9
I know that I'm gonna need to run my Co ax cable from the antenna to the CB so what's the best day to get it into the cab? Doors jam? Or drill a hole somewhere Anne put a rubber gromit in there to seal it off from water?
schneiderz
Alpharetta GA
ford
2.3 4 cylider
I went through my firewall
86MUDRCJ
8
Sheridan, CA
2.9
So you went under the truck then?
02RangerXLT
53
NE
4.0
My era of Ranger has a grommet in the floor right below your feet when you're sitting in the truck... So that's where I ran mine through.
86MUDRCJ
8
Sheridan, CA
2.9
I didn't see one so maybe ill have to run it through the firewall but that's alot of wire.
86MUDRCJ
8
Sheridan, CA
2.9
Lol I have a ahole already in the firewall that is already there just need to run to radioshack and get the Co ax.
06RangerXLT
54
Georgetown Ontario
4.0L
remember, antenna and wire should be the best quality you can buy.
86MUDRCJ
8
Sheridan, CA
2.9
Care to elaborate? What would you recommend for wire?
4x4junkie
Forum Staff Member
580
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
Mine has grommets in the rear cab floor behind the seats. I cut a hole with an Xacto knife and ran the coax cable through there.
RG-58U cable is fine for CB (<30 MHz) IF it has a good-quality shield braid (or a 100% foil wrap). There's literally tons of crap 58U cables that don't have this however (Radio Shack's garbage is probably the absolute worst these days :no2: ), your chances of getting a good quality cable are much better if you stick with RG8X or 8M cable (which will almost universally have a foamed center insulation too, which is also better).
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
rg8x gets my vote.. i don't use 58u.. had to many coax issues in the past..
88ranger89camaro
Firefighter
Squaw Valley, CA
2.3
please for the love of your CB dont go to rat shack, find a truck stop or CB shop that has the rg8 and not mini 8 (rg8x) ....... i know all my rat shack has is crap for coax
I hope you also know about setting your SWR so you dont fry your radio, if not ask, ill post up what you need to know
edit: mini 8 will be ok IF you are not running a linear (amp)
86MUDRCJ
8
Sheridan, CA
2.9
Can I just get the cable at any CB store? Or would it be best to just bring in my antenna in and have them hook everything up?
please for the love of your CB dont go to rat shack, find a truck stop or CB shop that has the rg8 and not mini 8 ....... i know all my rat shack has is crap for coax
I have no idea what you mean soif you could I'd like to know.
4.0B2
151
Walls, MS
4.0 v6
rg8 is what i meant... forgot that x was the mini, i dont' use the mini stuff..
should get it any cb shop or truck stop. idk for sure tho, my dad ordered 5000 foot of it a long time ago.. hahahahahahaha
Staff online
Kirby N.
March Truck of The Month
