94 ranger/97 explorer 5.0 swap
Thanks to all for your suggestions. I have the motor and trans installed and working great. I had to use the explorer hvac box, evap coil and blower motor housing. I also swapped the dash, steering column, pedals and wiring harness. The last obstacle I am facing is the a/c lines. The explorer lines will not fit the 94 condenser and the explorer condenser is to large and will not fit the truck. Any thoughts would be appreciated. The e-303 cam sounds and performs great. Unfortunately, I had to use the stock explorer headers for now, and the pass. side is extremely tight. I ordered 2 sets of headers and neither came close to fitting. All in all, the swap was wasn't to bad. The trans cross member and drive shafts fit perfectly. I used a 2 core alum. radiator and was able to retain the stock fan. Next time I will use a 96 up ranger to save myself a lot of work. Thanks again to all.
