Base plates for a tow bar
Fun_size_B2
Hello out there.
So here's my situation.
I'm buying a B2 thats a few hours away. I thought I'd be able to rent a car trailer an go pick it up but my vehicle doesnt meet the towing specs to pull a car trailer w/ a B2 on it ... so a rented car trailer isnt happening.
Then i thought car dolly but the few rental places nearby dont have one on hand.
My Plan C was to buy a tow bar so I did.
I've never used a tow bar before so i started looking up information on tow bars and B2's. There's not too much out there.
I read that I will need tow bar bases. So i Googled that an found 2. One on etrailers for $300 and another called blue ox for $425
This is more than i wanted to spend, i dont plan on towing this B2 around. I just need to pull it home.
Does any one know of any other options for tow bar bases that won't cost as much?
The B2 is in need of minor engine work so driving it home is not an option.
Thanks in advance for any help.
alwaysFlOoReD
5,080
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
What year b2? there is a difference in the bumper mount, I believe 88 up is the split. I made my own for the 88 up. I also did one on my 93 with the pieces that came with the tow bar...drilled some holes and mounted directly to the bumper, make sure the bumper has all the bolts and tightened properly.
FYI bumper chrome will dull a drill bit, grind a spot off first.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Or, you can rent a pickup that can pull the BII on a trailer. Get the Truck and trailer from the same place. Doesn't U-Haul rent trucks? May be worth checking out, Just my 2 cents worth.
Fun_size_B2
Thanks for the FYI i may go that route. How far did you pull your 93 after you drilled into the bumper?
The B2 I'm going after is a 88.
Fun_size_B2
Thanks for your 2 cents. I'll check into it.
alwaysFlOoReD
5,080
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've towed it locally. I personally would have no problem going cross country. There's the bracket in front and another piece of slightly bigger metal behind that sandwich the bumper. Two bolts 1/2" grade 5 bolts and nylocks hold each bracket all together. Never use the same size backer as the bracket because it can act as a guillotine. Also have two 3/8" grade 70 chains with quick connects going from towed frame to towee receiver loops.
Before I had a trailer for my race truck I flat towed that all over the country. That had a quick release for removing the bumper and brackets for the tow bar that fit the quick release. I copied a quick release bracket made for vehicles towed behind motorhomes using a foldable tow bar.
