Tranfer-Case Motor
Richard Gregersen
What the heck does it control???
CHKNFKR
73
Illinois
545 CID
The transfer case.
It shifts the case between 2hi, 4hi, and 4lo. There is no neutral.
Richard Gregersen
In some of my last posts I have stated that when I let off the gas sometimes I hear a loud whine and if I push down on the gas I get a clunk, and the whine goes away. Would this thing cause that??? and is there a gear on it that could be worn out??? If so I do know I can get one of the transfer case motors local, but what getting about the gear??? Thanks
Doom's Day Custom
5
nj
4.0l
U-joints or axles
CHKNFKR
73
Illinois
545 CID
the whining and clunking has nothing to do with the tcase shift motor, and likely has nothing to do with the tcase, unless it happens while in 4hi or 4lo. I'm with D-day, the noises are likely driveline related, check your fluid levels, u-joints, and wheel bearings. sloppy u-joints will clank with any change in driveshaft speed(when you get on and off of the pedal) and the whining could either be a side effect of the u-joint, low fluid levels in the diff, trans, or tcase, or an early warning of a bearing failure.
Richard Gregersen
All u-joints are good I've checked them all out. This thing is driving me nuts!!! I would be better off it would just do it all the time then I would know what the heck is wrong with the dang thing.
