help removing shifter 2003 ford ranger
tmkf_patryk
alright, so I have to replace the slave cylinder, I read up alot and also got a manual for it.
one of the first few steps, remove the shifter from transmission
so, my ranger is 2003, 2wd, and its got plastic molding trim, so I remove the 2 screws with ease and then theres a threaded bolt and a nut
i take the nut off the passenger side onto the drivers side, thread it, then get stuck, try as hard as i can, very very slowly turning but it just keeps getting harder, i take off the nut and see i started damaging it, try a few more times and nothing, there is noway it will thread on, the previous owner must have put lock-tite on it or something, it is physically impossible, only thing i have yet to try is my 4 foot long breaker bar (already thought i broke the shifter twice when the thing just jumped off)
so i need some help or tips what to try next, there must be a way of removing it off the transmission
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
i just remove the 3 torx screws down at the base of the shifter and remove the whole thing. only time i bother with what you're doing is to replace shifter bushings
tmkf_patryk
its already pitch black outside (i live far north) so i will get at it tomorrow (even though its in the garage)
I will guess that i will have to lift the plastic trim and find the 3 torx there
if there is anything else, let me know, but you helped me so much
thanks! (no thanks to the haynes)
i hope this info is good for the 03 as you got an 89 :p
3,612
Brutus knows what he is talking about man. These transmissions have changed very little in the last 20 years.
First question, are you sure you are turning the nut the right way? If you are sitting in the seat and turning it trying to take it off the front of the shifter, from your perspective it needs to turn to the right. Next, make sure you have the right sized socket or wrench on it. If I recall it's a 17mm.
If all else fails, vice grips.
I will say though, I like Brutus' suggestion. I couldn't figure out how to get the shifter off the first time either and so I just took the Torx screws and the plate off. I find that makes it a lot easier to get the trans to clear the floor pan.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
This write up is on something else, but it shows a pic and description on how to remove the shifter.
CLICK HERE
Kirby N.
March Truck of The Month
