Motorcraft 5W-20
hihoslvr
Banned
--- Banned ---
'04
F.O.R.D.
3.0
Just searched throught the threads for info on oil and didn't find much. I use the recommended MC partial synthetic, I'm at about 43,000 miles, and usually change it between 5,000 and 7,500. Just want to know anybodies thoughts on the subject. thanks
michowski
2
5w-30 is what you need. That is the correct weight oil for the 3.0. Stick with the motorcraft and run that weight. Otherwise sounds like your doing everything great.
Southern3.0
New Port Nowhere FL
'96
2.3, what a turd...
Ford Changed it to 5w 20 for the later model 3.0's, My '02 calls for 5w 20 and he's got an '04.
I use Valvoline or Castrol with a motorcraft filter and normaly change mine between 4000, and 5000. I know ford says you can go longer but I dont like to, by 5000 mine gets pretty dark.
Wicked_Sludge
42
Westport, WA
3-point-GO
5-20 is the proper grade for his engine. 5-30 is right for your motor, michowski.
stay away from fram filters. motorcraft or wix/napa is all i'll run.
hihoslvr
Banned
--- Banned ---
'04
F.O.R.D.
3.0
alright, thanks. I like to use the MC filters too, but last time I went to Wal-Mart, they didn't have 'em, probably ought to check with the dealer, and compare prices... :icon_idea:
pillen140
45
winston-salem, NC
ford
3.0
you should see newer toyotas, they are running 0w20, its like water. i dont think i could even put that in even if they recommended!!!
hihoslvr
Banned
--- Banned ---
'04
F.O.R.D.
3.0
yeah, ya know what else is funny: I bought my truck CPO (certified pre-owned) with 3,000 miles on it, and the dealer apparently had taken it to Jiffy Lube (had the sticker on the windsheild), they put 10W-30 in it!
bikerboy
Lancaster,PA
3.0
i run mine with 10w-30 in it. havent had any problems with it. the only reason i do is because where i work we get 10w30 in bulk and its super cheap. also most fords are supposed to run 5w-20 in them. ford put out a TSB saying to change almost all fords into 5w-20 instead of what was originally suggested.
shadetree
9
East Texas
Explorer Sport
4.0
Why? It's still 20w at operating temp, same as Motorcraft. shady
Wicked_Sludge
42
Westport, WA
3-point-GO
Why? shady
because they are cheap. the filter media has a small surface area, the filters openings are small, the glue that holds the media to the can desolves and the media breaks free, the drainback valves rarely seal, the metal they use for the can is cheasy and flimsy, the threads are buggered up right out of the box...they are just terrible filters.
they do have that nice grippy stuff on the end of the filter...i wish wix would do that to theirs!
shadetree
9
East Texas
Explorer Sport
4.0
They are the same price as Motorcraft at my Chinamart.
How much should it have? What is the criteria?
How large should they be? Criteria?
Do you have verifiable evidence of this on a large scale as to cause massive problems.
Again, evidence?
I have used these filters for many years and have yet to find bad threads. From my experience, the can is a good as any other. Other filters bend just as easily when using a filter wrench to remove them, so I haven't noticed that much difference.
I'll ask you the same question I have asked others, and as yet have not received an answer. Can you prove to me with verifiable data the statements you have made that have had a major effect on automobile engines.
The last time I checked, Fram outsold the closest competitor (Purolator), and all other filters combined by a 2 to 1 margin. With that much production, and with the problems you say they have, it should be very easy to verify your statements.
A novice cannot cut open a filter, look at it, and make any sound opinion on how it performs. That is what happens in most of the so called "studies." It's all assumption.
I am also aware that some 20 years ago Fram had a bad run of motorcycle filters. I think that is where this myth got started. shady
Black'03LevelII
25
Brunswick, Ohio
FORD
4.0L SOHC
+1 on Shady's questions.
I have been using Frams tuff guards for many years with absolutely no problems. and they flippin "motorcraft" one that was on my truck when I bought it split a seam about two weeks after I got it. suppsoedly the oil was changed a week before I got it and yes the filter looked brand new. Tossed that P.O.S. and put me a Fram TG filter on.
Wicked_Sludge
42
Westport, WA
3-point-GO
im not basing my claims off of what ive "heard" or off of what happened 2 decades ago. im basing my claims on what a guy who sees a lot of oil filters in a day (and has for 6 years now) has noticed over the years.
when i said cheap, i wasnt referring to price...i was referring to quality. just like if i said "cheesy" it wouldnt mean the filters were indeed made of delicious sharp cheddar.
there is no "criteria" for filter openings and media surface...but anyone who isnt just looking to argue knows more is better (more media means the filter will not plug as quickly, thus reducing flow, bypassing, or allowing crud through the media).
when you spin a filter off of a vehicle and shake it and the media rattles around inside the filter, thats a bad thing...and ive ONLY seen this on fram filters...a dozen times over the coarse of several years. sure its acceptable in any mass produced item to have a few "bad apples" (again, i dont mean actual apples)...but it happens more often on frams than other brands.
Again, evidence?
you can visually see that the drainback valve is not sealed on many used fram filters. the valve is distorted...even on some right out of the box.
ive bent fram filter cans by hand while installing them. ever give a fram a little squeeze? feel the metal bend and warp under your fingers?
im not spouting half baked claims to the public shadey. im speaking from experience. so youve had good luck with fram filters, im glad for you. i havnt. personally if i hear negative things about an item, i try to steer clear of it...especially when there are higher quality options for nearly the same price.
skippy
38
Georgia,USSA
ford
2.8l durasparked rice killer
i have been using fram filters since my first car in 1972.i have had 0 failures.
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
