1988 bronco II fault code 64
rochhound
arizona
ford
4.0
i have a 1988 ford bronco II 2.9
i have engine code 64 (air intake temperature signal low)
when its cold idle is very low after warming up code goes away and idles ok
my question is what componet or part is causing the problem?
thanks steve
IIBRONCOS
11
AZ
2.9
The intake air charge temperature sensor is on the upper intake manifold passenger side. It is an inexpensive and easy part to replace.
Search online for an ACT sensor (Air Charge Temperature) sensor. Don't forget to clear your computer code.
Members online
Today's birthdays
Shran
April Truck of The Month
