Rpm gauge acts weird
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
For the year and a half I've owned my truck I have to hit my dash board because sometimes my tachometer won't work, but if I hit it it'll bounce back up. Anyway to fix that, or has anyone at least had this issue? It's a 99 ranger.
alwaysFlOoReD
5,081
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I have a neon that does the same with the speedo. They are famous for that. The fix for the neons is to pull the cluster and look at the the soldering job. Sometimes the solder has a crack that needs to be reheated to let it flow back together. I'm not saying that's the case in your truck but is a possibility.
Good luck,
Richard
Sent from my XT1032 using Tapatalk
Coolguy21
3.0 v6
Pull the dash and check the plug that the tachometer plugs in to
Coolguy21
3.0 v6
Mine is doing the same thing but i think it might be the tachometer itself in my case
Hawk1339
Ohio
FordFord
I agree with Coolguy, the gauge sockets get dirty/oxidized and the connection fails. Clean and re-seat.
