skinsfan
- Feb 1, 2016
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
I have a 1999 Ranger reg cab 4x4, AT, 6 cyl. I have a rumbling noise in the front end. Makes a sound like knobby snow tires at highway speed. However, makes this noise starting at 10 mph and gets worse with more speed. Seems worse on drivers side. Might be because that's where I sit? Ha. We had 17'' of snow a couple weeks ago and I used the 4WD for a few days. Seems like it's been making the noise since then. When I went back to 2wd, I did the old put it in reverse trick(whether you need to or not). So here are the dumb questions.
1. Could this be wind up pressure on Tcase or pressure on something else?
2. Wheel bearings? Maybe? Pouring rain right now, when it stops I'll jack it up and tug on tire.
3. Any other thing that I should be looking for?
Did not have this noise before the storm. Seem's like a huge coinsidence for bearings or CV joints to go bad right after I used 4WD. Coinsidences do happen. Thanks in advance!
