How not to tow a heaver load!
Mac
183
C. Wisconsin
2000
199
4.0
Make sure the towing vechical is capable and heavy enough, think maybe electric brakes might have helped a bit. Maybe an equalizing hitch, always used them on the horse trailers.
Dave
http://www.youtube.com/watch?v=2N_HOnYcVLA
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,819
SW Iowa
Engine Type
V8
5.0
That homemade looking deckover trailer sure didn't help either. The wider stance and lower CG of a normal car trailer would have helped a lot.
For as hard as it looks like it wanted to go right I wonder if he blew out a spring or tire and overcompensated for it.
Electric brakes would have helped, but I think his taste in trailers and tow rigs had him just about screwed from the start.
My all time favorite towing fail:
http://www.youtube.com/watch?v=AyXgMal3C1U
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I think a little bit of driver competence might have helped there too.
I've had trailers get wobbly on me before. Ones as big as my truck too. Never lost one like that though.
Then again, I know that when the trailer starts getting wonky you need to slow down and get her under control again.
88_Eddie
Solid Axle Swap
155
Raleigh, NC
2.9L, 4.0L
i think the larger mistake was using a car to tow something that needed to be towed by a truck
the last video was just funny. do something stupid, dont be surprised when bad shit happens
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
Yeah, it looks like he was going along at a pretty good clip, definitely too much trailer for that tiny truck. Would have been fine if he kept to the side roads. He should have slowed way down at the first sign of wobble instead of trying to steer out of it.
However, I'm guilty of towing home my dad's Ion on a flatbed trailer with my '97. I never went past 45 though, and it did have the wheels on the side for a lower CoG.
Heh, In Soviet Russia, trailer steers YOU.
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
That is too small of a car with too much trailer, but it's because they couldn't put enough tongue weight on the tow vehicle. That is exactly what happens when you don't have the weight far enough forward. I've had to stop and adjust loads before because of that motion. He shift the load forward a couple feet and there isn't enough mass behyind the trailer axles to get that deadly oscillation going. Driver skill had nothing to do with that--except that he didn't have enough experience to know not to do it. It probably seemed okay at low speeds, but when he pulled onto the freeway it quickly kicked his asteriks.
CaseyVR6
Claryville, NY
Mazda
4.0L
/\ Agreed. Inexperience lead to a bad call on load placement, but that's called a "death wobble" for a reason...
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
When a trailer starts to sway the USUAL cause is insufficient tongue weight.
To damp out the sway two courses of action work reliably,
1)applying the trailer brakes
Or
2)adding power in the tow vehicle
the obvious issue with going throttle up is that you now have to slow down from an even higher speed.
What the first jackass did was trying to "Damp out the sway" with steering corrections.
Somewhere less than 3% of drivers can do it correctly out of phase to damp out the sway
instead of reinforcing the sway.
Generally speaking if you feel it swaying stop and adjust the load on the trailer.
What you see is epic fail on multiple issues.
AD
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
Good to see you around Allan.
shane96ranger
221
Utah
Ford F150-Stang
Engine Type
V8
4.6 Triton / 5.0
Poor M3. That's one of the very few foreign cars I don't mind.
hondaxr650
4
Tacoma, WA
4.0
I worked at an equipment rental yard in high school. One of our delivery guys lost a small excavator that way. Flopped it over on top of an oncoming car and killed a lady. Scary stuff.
p38fln
Superior, WI
3.5 L GTDI
From my experience with trailer sway with a severely underpowered vehicle and no way to manually activate the trailer brakes (U-Haul trailer) -
Best and simplest way to stop it is to FIRMLY grip the steering wheel and keep it from turning at all. The swaying motion stops in a few seconds.
Members online
Today's birthdays
Shran
April Truck of The Month
