The only time I've ever heard a "swishing sound" was when a disc was worn to the point of
metal-to-metal contact between the disc and the pressure plate inertia ring or the face of the flywheel...
the throw-out bearing is under constant load from the day it is installed until the day it is removed and replaced.
in Ford's words: "the release bearing is a constant contact & constant run"
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
