302 transmission
scxc15
East Tennessee
2.9L V6
Ok guys I could use some help. I have a 87 4x4 Ranger with a 302 engine and the stock 5-speed tranny. The tranny is messed up and I really don't wanna stick another ranger one in, instead I'd like to swap to a 5-speed F-150 transmission. What years will work and are there any clearance issues?
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
'77 ???? Apparently the '97 up 4.2l 5-speed tranny fits best as far as shifter position and will bolt up to the 302.
Richard
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Ok, a 77 did not have a 5 spd stock. What trans do you have (m5odr2 or ZF 5 spd)? And what Tcase do you have?
SVT
scxc15
East Tennessee
2.9L V6
I have a 88 ranger stx with a 2.9L v6 and a 5-speed. I bought my 87 ranger that already had the 302 in it and I assumed it was a factory ranger 5-speed. I guess I need to look and see...
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Rangers started in 1983(midsized trucks) rangers with the 2.9 started in 1986... Unless someone transplanted that engine, you might have your years mixed up :icon_thumby:
SVT
scxc15
East Tennessee
2.9L V6
SVT
87 and an 88***. I can't type tonight sorry guys
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
That's ok, just wanted to keep the info clear... :D BTW, The stock ranger trans is the M5ODR1, and will not bolt to the 302, the M5ODR2 is the stock 5 spd in the f150, and is found behind the 4.2 v6, which shares the same bolt pattern as the 302. It's likely you have the r2. If you have a pto cover on the bottom of your trans near the front, then you have the ZF 5 spd...
SVT
scxc15
East Tennessee
2.9L V6
fixed haha. Anyway what transmission will work lol
scxc15
East Tennessee
2.9L V6
SVT
I think i have the R1 with the aftermarket adapter plate...
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Do you have a plate at least 0.250" thick between the motor and trans(metal or aluminum)? If you do, then i would agree with you...I'd definitely get an R2...
SVT
a_aarong96
I don't know what transmission I should put in my 89 ford ranger
I own a 1989 ford ranger and put a 302 motor in it but don't know what transmission I can or should put in it. I went to the junk yard and found a 96 model ford f150 6 cylinder 5 speed and didn't know if that would work in my truck or not... please help.
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
If it was the I-6, 302 or 351, it'll bolt up and fit...
SVT
Jordanhost1998
Houlton
Ford ranger
Would like to know the same i have an 88 ranger 4x4 but would like to know what it takes to put an f150 5 speed in it ?
Staff online
Today's birthdays
Shran
April Truck of The Month
