1989 2.9l 4x4 swap to 1990 4.0l thats also had 4x4
Tictac1994
FORD
So i pulled a 4.0l out of a 90 and grabbed the harness and ECU and believe i grabbed the map sensor since its speed density. What is the rest i need to convert and does my 89 have trans cooler or should i pull that from the donor truck as well, both are auto's and same transmission. So pretty much what all do i need to have for the conversion. And what can i remove off my truck that wont be needed.
I already been through few threads but most of it was minimal description
:dunno:
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
there's no such thing as a "speed density 4.0"
The early 4.0's do have a MAP sensor but it would also have a Mass Air sensor mounted to the air box...
AD
Tictac1994
FORD
So i am missing the maf sensor and the rest of it....i asked the owner and he said "i dont think it had a sensor" he looked lost when i said MAF i dont think he even knew what it is
Tictac1994
FORD
AD
I replied
Tictac1994
FORD
AD
So what output are the injectors on the 90 4.0? And do you know by chance where on the harness the maf plugs into cuz there was a few burned up connections on the harness that were already there before i showed up
Staff online
Today's birthdays
Shran
April Truck of The Month
