turn signal/reverse fuse blows when i hit the brakes...
mattc113
2
Okc, Ok
Engine Type
V8
5.7
2WD / 4WD
Solid Axle Swap 4x4
8"
37"
anybody else ever have this problem? 89 bII
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
You probably have an exposed wire somewhere.
mattc113
2
Okc, Ok
Engine Type
V8
5.7
2WD / 4WD
Solid Axle Swap 4x4
8"
37"
...i hate exsposed wires!
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Check your brake lights. The brake bulbs and rear signal bulbs are the same bulbs. You probably have a burnt brake filament that is resting across another filament.
Staff online
Shran
April Truck of The Month
