speed1995
- Aug 18, 2010
- Reaction score
- 0
- Location
- Grand Rapids, MI
- Make / Model
- Ford
- Engine Size
- 2.9
- Automatic
I have a 1990 Ford Bronco II with the 2.9 and A4LD. I had a similiar problem with the 1986 Bronco II I sold where the wires to the coil were bad so it woud stutter and die when you went to move. I just replaced the fuel filter on the 1990, but it has still been acting up. It will run perfect for 5-10 minutes and the just die out. I have a fuel pressure tester which showed that it would all the sudden slowly lose fuel pressure. I would like to get this fixed before I drop my tank. It seemed to be fine before, but I did not get to drive it much. It only has one fuel pump in the tank and the fuel lines are fine. What do you think?
