Time to pick a drive line
lchappyjr
Kalama, WA
With the Explorer motor and transmission in its time to set the rearend. With the 6" Skyjacker lift on im worried about what driveline to use. I have the old explorer one, can I just cut it down? or find something else. I need to know what my options are. Its going to be my daily driver so I can leave my truck hooked to the boat.
A chopped down Explorer shaft is a good option.
If you can find an F-150 front shaft from an 04-08 I hear those work nicely too.
camshaft01
ridgecrest,ca
ive been running a cut rear shaft for 3 yrs and have not needed to install my spare shaft yet. ive havnt checked out the f-150 driveshaft yet, thats a good idea, cuz i bet they are thicker. the exp shafts will suprise you at how steep of an angle they will run. i didnt balance mine, and it runs smooth, but i did get it welded straight as an arrow.
lchappyjr
Kalama, WA
thanks guys, once I get these shafts in Im moving to fuel, fluids and fabbing a cable bracket for the floor shifter, unless a mustang auto floor shifter will work.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
You'll probably want to use a double-cardan driveshaft since you have the lift on it (especially if you'll be DD'ing it). The F-150 front shaft sounds like it would be a good option (I have a '91 Explorer front shaft as the rear shaft on mine).
lchappyjr
Kalama, WA
Do you set the rearend angles the same for the double-cardan shaft?
They aren't really that thick. About the same as the stock rear shaft on the B2.
The big advantage is that they are plentiful and have u-joint, not CV joints.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
No, with a double-cardan the pinion gets pointed more upward so that it's straight inline with the shaft (I still put about 1-2° down to account for windup of the leafsprings however).
