disciplerocks's B2 build thread
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Picked up some SVT Focus seats. One needs repaired, but they should be pretty nice once I mount them.
44 is out and ready to be put in the F150. 60 mocked up just to get the B2 back off jackstands.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Still using the hydroboost?
SVT
disciplerocks
53
Evansville, IN
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
What exactly is the hydroboost?
disciplerocks
53
Evansville, IN
It uses the PS pump for brake pressure instead of manifold vacuum.
dangerranger83
54
Lafayette, IN
I assume that this can't be adapted to a ranger easily if somebody wanted to.
disciplerocks
53
Evansville, IN
Could be. This unit is from a Mustang.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I've got a superduty hydroboost on SVT, its not hard. For comparison, a vacuum brake booster is capable of about 1800-2000 psi of brake pressure. A hydroboost unit is cabale of about 3500 psi of pressure. What's this mean? More brakes with less pedal effort...
SVT
dangerranger83
54
Lafayette, IN
That's what I want to hear Sive I'm going to be doing an explorer 8.8 swap and as tine goes on more steel will be added to the truck weighing it down, etc...
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Well, SVT's sitting in at about 7k lbs, and even though a diet is in his future, he's gonna end up at 8k easy when the new axles go in...
SVT
disciplerocks
53
Evansville, IN
Updates!!!!
Picked up a metric D50 for a steal. Decided to stick with it instead of converting the Dodge D60 to Ford lockouts. Then picked up a Sterling to match, and a parts D50.
disciplerocks
53
Evansville, IN
Mounted 2 tires
Pulled the 8.8 and dropped in the Sterling. Need to add lift blocks back in.
WoodyB2
Vancouver,WA
Looking good man! glad to see this thing getting some love
dangerranger83
54
Lafayette, IN
He's creating a monster.
disciplerocks
53
Evansville, IN
As some of you already know, I lost the V8. As well as my B2 and most of my garage.
