88' transfer case wiring to 4.0
Oravec
i have an 88' bronco II. had a mishap long story short i ended up putting a 4.0 from a 98' explorer in it with a 94' harness so i didn't have to deal with obdII. it was not a smooth operation because the explorer had a wider chassis. i took out the old harness and threw it away, too bad i also threw away the transfer case/transmission wiring for the 4x system. i realized this when i tried to use it, it functions fine in 2wd since its a manual. wasnt sure how or even if its possible to get the part of the harness im missing and splice it in. the harness is out of a 2wd automatic truck. it also spits fuel and fouls out my plugs in two weeks or so. any help on what to do about the plugs or where to find a wiring digram would be greatly appreciated.
Earl43P
38
Farmington, Pa
Ford F250 4WD
