Explorer coils on 89 BII 4x4
Jecsd1
Hey all, my coils are sagging and was going to hit the junkyard. If I grab some coils from an explorer can I expect any lift?
Lift isn't my goal but if I can get an extra inch or so that's cool. If i do grab some explorer coils should I be looking for 2wd/4wd, 2 door or 4 door?
Thanks!!
Jecsd1
Anyone have any info on this?
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
All I can suggest is to find a site that sells replacement springs and compare rates. My gut feeling is that a 4x4 four door explorer would be slightly more rate than your stock coil.
Richard
PlumCrazy
2014 Truck of The Year
168
Millersport, OH
Solid Axle Swap 4x4
We put 94 4 door Expo springs in the B2....it rides/flexes like a shopping cart...that's with out sway bars
Mr. Tarkanian
Central KY
2.9L
I've been researching this myself, and here are the numbers I'm coming up with:
Bronco II factory spring:
-Load height 11''
-Spring rate 369
91-94 Explorer 4 door factory spring:
-Load height 11.5''
-Spring rate 485
These numbers are according to the NAPA database. You should THEORETICALLY get at least an inch or more of lift, but you know how that goes.
richard booth
28
Tacoma wa
2.9 for now.
I put 93 or 94 explorer front springs on my 88B2 when I rebuilt the front end and it sits killer but has a noticeable amount of positive camber so I will have to change the camber bushings out for adjustable ones so I can get it corrected. going to order the bushings and spend a Sat doing it.
