FM145 to FM 146
CarsonChris
4.0/2.9
The ends from the master cylinder are a little different from a 145 to a 146. Anybody know if the line at the cylinder will leak if I use the shorter connector from the 146 into the master or should I Just cut the connectors off and swap ends?
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Why not just use the correct line?
Staff online
Today's birthdays
Shran
April Truck of The Month
