This is the first attempt at getting it to run under its own power. It does not run well but it does run!
I have several codes popping up already,
P0135
P0155
P0176
P0708
P0743
A couple auto trans related codes, a couple o2 sensor codes, and a flex fuel code.
Ok, Ok, on with the video, just remember, this is the first start and it does have open headers and no o2 sensors!
http://vid256.photobucket.com/albums/hh168/jbrown1238/IMG_0955_zpswo889blc.mp4
I will not have any time to work on the truck until after the Christmas holiday. However, if any of you have any comments or suggestions on what might help with the rough running of the engine please feel free to reply. Any help would be greatly appreciated.
My son and I decided to set the balancer at “true” TDC and not the “0” mark on the balancer for TDC. At the same time we went ahead and moved the cam sensor/synchro one tooth and realigned. The truck has run four times for approximately 40 seconds each time. I am trying to keep the exhaust/head temperature down until I have an exhaust system installed. It has not yet been brought up to operating temp. It has good oil pressure and good fuel pressure.
