where to buy a bodylift?
jovibuilt
9
Spruce Pine North Carolina
ford
4.0
I know all the places to get them.I just want to know if anyone knows where to pick up one for a good price.Summit want 138.00 for one.I just wanted to know if there was a cheaper option.Its for a 1989 extended cab ranger.Thanks
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Well I know were there is a plaza with a sporting goods store and a hardware store next to each other.
Bet 10 hockey pucks and some new bolts don't cost that.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Seriously, are hockey pucks a viable option for a mild lift?
No sarcasm intended.
I'm only wanting a 1 to 2 inch body lift on my B2's
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I have seen it done. It kinda works. The problem is that even though they are made from the same stuff, hockey pucks are not as hard and break down faster.
chrwilkins30
6
Mishawaka, Indiana
2.9
jcwhitney. if you only want a 1in performanceAccesory sells just the block.
superds
80
ND
Ford Bronco II
Engine Type
V8
5.0
2WD / 4WD
2" body. 1.5" coil spring spacers/rear block
+1 what chrwilkens said. I picked up just the individual 1" body lift blocks from Summit for about $1-$2 each. Now I just need some bolts/nuts/washers at $1.69/lb at the local hardware store and I'm set. Although, I might splurge and pickup stainless or even metric (both cost a bit more). You will need to go to Performance Accessories website to get the part numbers and then just enter them into Summit's search to find them, I don't remember if the individual blocks are listed unless you search the part number.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
This is what I was wondering. Cause hockey pucks are the same price.
superds
80
ND
Ford Bronco II
Engine Type
V8
5.0
2WD / 4WD
I agree with you, with real lift blocks as inexpensive as they are, why use hockey pucks?
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
1" lift blocks are a 1.99 on Summit. My B2 needs 6 or 8. So with grade 8's and washers, were talking under 25 bucks.
Feel free to correct me if I'm wrong.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
2" were 3.99 and 3 " were 5.99. I might go with 2" not entirely sure.
superds
80
ND
Ford Bronco II
Engine Type
V8
5.0
2WD / 4WD
You're correct, I just searched Summit for them and you can find them without knowing the part number. I searched for "Performance Accessories" and blocks came up as an category to view all the items available. I found the same price for 2" and 3" diameter blocks (both 1" tall).
For some reason 14 comes to mind as the number for a Ranger. Six 3" diameter for the cab/hood/fender area and the rest as 2" diamter for the box. I could be wrong, it was quite some time ago that I looked at them on my Ranger and it's not near me right now to check it out. It seems like a lot compared to what's on your BII, maybe my number required for the box is too high, at least if I ordered 14 I won't be short!
Staff online
Members online
Shran
April Truck of The Month
