Replacing headlight lens on 89-92 Ranger
Fairlaniac
10
Denver, PA
My headlight lenses on my '89 are fogged on the outside and the inside due to a crack. So I picked up some nice clear, crack free headlight assemblies. The black plastic housing (bucket) they fasten to is broken so I've taken one lens off the "bucket" to put on my truck. Of the three plastic winged looking nuts I broke two. How do you remove these without breaking them? I tried to gingerly remove them but didn't work. I don't want to break the ones on the truck currently so I can reuse them. It appears the "winged" portion is split and the piece against the bucket has two nubs that look to retain the "wing". It looks as if you could pry the lower part of the "wing" up they would turn easier and prevent breakage? Any hints or advice is appreciated.
Thanks,
Protowrxs
Shawnee,OK
2.9 - 4.0 Waiting
They were a pain for me as well. My old lenses were crap and I had some new ones from ebay so I just cut the plastic up on the old lens until I could get the black wing nuts out. Then I snapped them into the new lens, used a flathead screwdriver to spin them into lock position and everything went back together without even realigning headlights. If you are trying to get them off the ones you want to reuse then that's of no use I guess.
