maybe getting a BII, what do i need to look for?
petruccifan88
4
Greer, South Carolina
2007 & 2015
2.3 2wd & 2.7l EcoBoost FX4
31x10.5 and 33
When life gives ya lemons, ya blow them lemons to bits wit ya laser cannons!
I am going Friday to look at a 1986 Bronco II V6 4wd. the guy wants $500 for it because its got some troubles and he don't want to go through those troubles.
Here's the link to the CL ad.
https://greenville.craigslist.org/cto/4847472988.html
what things should i be wary of?
Mileage is around 64,600 or so
so im guessing 164k at the least.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Not much you can really check except what you can see.
You could check the tranny fluid, smell it.
Oil is probably drained but check it anyway
Remove gas cap and smell, see how old gas might be, i.e. varnish smell.
Look close at the wiring, 29 years for DIYers adding tape decks and CD players can take there toll, lol.
So pay attention to non-stock wires
Odd about front drive line, BII should have auto hubs so removing drive line to save gas doesn't make any sense at all, even for a novice mechanic.
Transfer case locked in 4hi, then it might make sense, lol.
Make sure all the parts are around, '86 BII is getting pretty old so some parts can be hard to find.
Whats your plan?
As it sits now you are just buying a frame and body for $500
In any case it looks like a big project
petruccifan88
4
2007 & 2015
31x10.5 and 33
Not sure yet on what i'm doing with it. My thinking was why tear up the daily driver Ranger when i could get a cheap RBV and tear that up? For now I would use it for around the property. Maybe later on i could turn it into something crazy. I know the limitations of the D28 and the electronic shift 4wd, but as long as its working for now, cool. Truthfully, I wanted a project, something that i could fix up and put all that stuff i learned in school to the test. Working at O'Reilly Auto Parts is probably a plus as well.
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
If that body is rust free then I would pay $500.00 for it. The motor and trans are a wash, if they run great, if not throw in a 4.0 and plan on rebuilding or swapping the trans. Crawl around under the truck looking for rust. Check all the body mounts as well as floor pans. Take a close look at the firewall for signs of water leaking, leaves can fall in thru the cowl and promote rust. Behind the kick panels by the front doors. The body mounts by the rad support. The rad support itself.
I really like my b-2.
Good luck,
Richard
NEALD
Also check rear body mount area just ahead of where the rear bumper mounts on the frame.
petruccifan88
4
2007 & 2015
31x10.5 and 33
This is awesome. I am the new owner of a 1986 Bronco II!! This thing is rust free. We almost had an issue getting it home but it is here! I couldn't be happier maybe if it ran, but it turned over a bunch, the distributor is loose, so if that is fixed it might run. Beyond excited!
alwaysFlOoReD
Forum Staff Member
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Start a build thread with lots of pics. Its a great tool for down the road when you can't remember what you've done to the sucker.
sent while sitting on the throne
petruccifan88
4
2007 & 2015
31x10.5 and 33
Thanks guys for all your help. I will start a build thread tomorrow when I can get some pictures.
NEALD
Very cool get some pics vs up! Have you got her started yet?
Aerkusa
Whats your plan?
My old BII had manual hubs.
ford
4.0
find one that already has the 4.0 and a manual trans. no more said
Staff online
Today's birthdays
Shran
April Truck of The Month
