Heat censor
tlcasey100
Can someone tell me the location of engine coolant temperature censor
A censor is someone who tells you that you are not allowed to say or write something.
A sensor is a device that detects stuff.
No take your newfound command of the English language and go find your coolant temp sensor in the lower intake near the thermostat housing.
8,370
There is one temp sensor and one temp sender used on the 2.9l
Temp sensor will have 2 wires, and is only connected to the computer
Temp sender will have 1 wire, and is only connected to the dash board temp gauge
They are both located near each other on the lower intake manifold towards the front of the engine, just above the thermostat housing, where upper radiator hose connects to engine.
