How to remove dash to replace bulbs on 94 5 speed
The Toolman
Lake of The Ozarks Warsaw, Mo.
99 Ranger Auto
4 cyl
Trim piece an then cluster
Title pretty much says it all. Couldn't find any instructions by searching this forum. screws, clips, push pins??????????
Thanx ahead of time
Ron.....
DIYnewbie
I'd like to know this too, also have a 94 5 speed.
UrbanRedneckKid
Solid Axle Swap
17
Cass Co, Missouri
4.0L
Remove radio if aftermarket, ashtray(tab), ashtray bracket(bolts). Then pull off the panel(clips).
Cluster is 4 bolts, 2 plugs, speedo cable.
Sent from my HTCONE using Tapatalk
Members online
Shran
April Truck of The Month
