OBDII connector not working
RDRanger99
Mandalay Arkansas
When I plug in my code reader and key on engine off it tells me link error.
I know my code reader works. What could the problem be?
ab_slack
12
New Joisey
2.9L
When you say "key on engine off" am I correct you mean you turn the key to run, but not to start to crank or otherwise starting the engine?
You aren't turning it to just ACC by any chance?
We have a 99 ranger here, and I don't recall anything funny using the OBD2.
Does it connect when the engine is running?
If it isn't connecting even with the engine running, I would think bad contact in the OBD connector or broken wire either in the harness or in the OBD2 monitor.
When you say you know the OBD2 reader works, have you tested it, verified it working in another vehicle after this problem? Just cause when things break there is always the first time it doesn't work. I assume this particular OBD2 works with Ford products.
RDRanger99
Mandalay Arkansas
Thank you for your reply.
Yes key in run position, but not to start/crank engine. And no, it still reads link error with the engine running. And yes I have used the reader on other vehicles and it works. And it use to work in my '99 Ranger. I looked for broken wires in the connector, but I'm no good at using volt/ohm meter. And I've checked the fuses. Any thing else I might could try?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Its fused with the cigarette lighter....check and see if that has power
Sent from my SGH-I747M using Tapatalk now Free
RDRanger99
Mandalay Arkansas
Thanks Sasquatch, I already know that my cigarette lighter doesn't have power.
I'll try and fix that tomorrow and then try my code reader again. :icon_welder:
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Usually just a fuse gone
