ranger_lover
- Mar 26, 2016
- Reaction score
- 0
- Make / Model
- FORD
Hello and thanks for your time. I will be soon getting ready to replace my bearings on a 99 3.0 ranger and I have had a hard time finding specific bearing information online. maybe I am just not looking in the right place, I don't know.
anyway my question is on the 3.0 Vulcan engine, range of 98-01 (4wd if that matters), what are the Main and piston bearing clearances for that engine? what I will need specifically are:
Clearance Specs between bearings
- NEW
- SERVICE LIMITS
Those are the two things I am having a hard time finding online, and haven't called ford yet but not sure they would help me. reason why I am doing this is because mine are so worn that a new front main seal lasts about the third time I drive it then I have a slowly worsening oil leak on the passenger side, bad enough that I am losing about a quart of oil every 100ish miles. that's another topic I have never found is an oil leak caused by worn bearings coming from the front seal, where you park you vehicle and come back to find a small line of drips on the passenger side.
anyway, thanks for your time and if someone could get those numbers to me I would appreciate it.
oh and if you wouldn't mind specifically saying which is for NEW and LIMITS, and I don't know if would need to replace them but if possible include the piston bearings clearances as well, and thank you again.
- NEW
- SERVICE LIMITS
