Explorer 8.8 axle swap drive shaft issues! Beware!
Axle_tek
Explorer 8.8 axle swap drive shaft issues! Beware! Help!
I installed a 8.8 out of a explorer in my 95 std. Cab 3.0l manual. The two piece drive shaft (double cardan style) bolted right up and work fine for a while until....it took out my t-case. Upon further inspection it is too long and was binding during hard throttle situations it took two years but it won the battle.
My angles are good it just a tad too long. Now I need a new t-case anyone have a manual 1354 laying around?
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
I know a guy here in Memphis that has one he may sell...
Axle_tek
After doing some research on TRS. The Pinion length (axle centerline to u-joint centerline) is the same between the two axles (ranger 7.5 to explorer 8.8) so what gives? If I roll the truck in gear causing the drive shaft flange to rotate up and down I bottom out the slip joint on the drive shaft fairly easily. The t-case Flange is lose and I must have damaged the crush sleeve I believe because the pinion yoke is loose and makes a clunk noise?
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
The pinion of the 8.8" is somewhat lower which changes the geometry when viewed from the side.
The pinion being mounted lower results in more linear thrust (forward along the driveshaft) during "Axle Wrap" situations.
Technically your driveshaft is a "One Piece" driveshaft because in terms of this discussion the slip yoke does not count.
What counts is lengths of tubing separated by U-joints an (example is a 1997 or earlier
Supercab)
Axle_tek
Hmm. I don't have the money to have a drive shaft shortened or made any ideas?
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Walk to work?
Costs about $30 to get a driveshaft shortened around here.
Axle_tek
It's about a 100 bucks here. They charge 20 to sand blast it, 30 to shorten it and 50 to balance it. It's crazy
baddis
Solid Axle Swap
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
I was always told that if you take less than 6 inches out of a shaft it wouldn't need rebalanced. I have done it myself but it is time consuming without a lathe to cut the weld down
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
I find that kind of bogus as there are usually weights on both ends of the shaft...
I ran an explorer 8.8 in my 97 3.0L reg cab short bed for 2 years and it never gave my any issue.
Axle_tek
Ok still no answer. I Also have a 8.8 axle in my other ranger and never had bottoming issues. That is why I posted this question Sasquatch_Ryda. How much slip yoke should be exposed? (Or distance between u joints in a stock ranger) I have nothing to go off of at this point (my other ranger is two wheel drive)
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
I've had my 8.8 in my '97 for a hair over 2 years now. Never had an issue?
Did you re-use your stock shaft or get one from another similar body type Ranger? Has the shaft been replaced? In 1998 (I think), the wheelbase and cab got stretched juuuust a bit, around 3".
Some rotational play in the pinion is fine, if it moves in/out or up/down, THAT is a problem.
If you completely collapse the driveshaft how much space is there between the driveshaft flange and the t-case flange?
Axle_tek
maybe a 1/16" and that's forcing it into the t-case and squishing the boot.
Captain Ledd
39
Michigan
302, 2.3
yeahh... that ain't nearly enough alright.
Long bed or Short bed? (I breezed through your previous posts and didn't see it) I have a short bed Reg Cab 97 4x4 parts Ranger that I could measure the shaft on. BUT it's at my parents house still behind the shed, and it's probably going to be closer to the end of October before I'm making a trip there :/
Did you buy the truck used? I'm seriously suspecting that this got a shaft from one of the newer, 3" longer, Rangers at some point somehow.
Staff online
Members online
Shran
April Truck of The Month
