Put a pan down
There is a low pressure pump, lift pump, in the gas tank so it will prevent the siphoning of gas in the tank out the open fuel line.
Pump in the gas tank and high pressure pump in the frame rail both share the same power wire, splice is near the high pressure pump.
This wire only has power for 2 seconds when key is turned on, but each time key is turned on
