Need help want to do a swap
B3ngerman olsen
Ok so I have a 4.6 v8 Triton and I want to put it into a 99 3.0 ranger with 4wd and auto. need to know what to do and will the motor line up with the trans. Also tell me all I need to know before diving in and how much it might cost.
To start, while not impossible, a 4.6 is a very tight fit in that engine bay. That is why the Explorer kept the 5.0 longer than any other vehicle. Be prepared to potentially lose your A/C. A body lift will probably help.
Anything can be lined up with anything else. That's not hard. A 4.6L engine will not mate up to a 3.0 transmission. The bell bolt pattern it wrong, I think the 4.6 flex plate won't even fit inside the bell, and the engine would probably shred that transmission.
Cost is hard to estimate. Each swap is different, and parts availability and prices will vary by location. Also, the 4.6 swap isn't as well documented as the 5.0 swap.
You will, at least, need an engine, trans, wiring, computer, and exhaust. You will likely have to do something custom with the steering, and as said before a body lift will probably make things less painful.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i would suggest to sell the 4.6 and run either an explorer 5.0 or a gm ls powertrain.
unless your just wanting to be different.
if you had a complete 4.6 powertrain trans and t case, that would be different...almost justifiable.
fitment would be harder then the 5.0 or ls my magnitudes.
