Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Reply
Thread Tools Display Modes
Old 05-17-2018, 12:45 AM   #1
B3ngerman olsen
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger
B3ngerman olsen is on a distinguished road
Default Need help want to do a swap
Ok so I have a 4.6 v8 Triton and I want to put it into a 99 3.0 ranger with 4wd and auto. need to know what to do and will the motor line up with the trans. Also tell me all I need to know before diving in and how much it might cost.
B3ngerman olsen is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Rock Auto Discount Code: 20B2FF503DCF74 Expires: September 28, 2018
Old 05-17-2018, 07:27 AM   #2
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
To start, while not impossible, a 4.6 is a very tight fit in that engine bay. That is why the Explorer kept the 5.0 longer than any other vehicle. Be prepared to potentially lose your A/C. A body lift will probably help.
Anything can be lined up with anything else. That's not hard. A 4.6L engine will not mate up to a 3.0 transmission. The bell bolt pattern it wrong, I think the 4.6 flex plate won't even fit inside the bell, and the engine would probably shred that transmission.
Cost is hard to estimate. Each swap is different, and parts availability and prices will vary by location. Also, the 4.6 swap isn't as well documented as the 5.0 swap.
You will, at least, need an engine, trans, wiring, computer, and exhaust. You will likely have to do something custom with the steering, and as said before a body lift will probably make things less painful.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 05-17-2018, 10:11 PM   #3
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Vehicle Year: 1988
Vehicle Make: FORD
Vehicle Model: RANGERISH SORT OF THING
I use this vehicle for: EVERYTHING
My credo: it is easier to fix and understand than "her"
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
i would suggest to sell the 4.6 and run either an explorer 5.0 or a gm ls powertrain.
unless your just wanting to be different.
if you had a complete 4.6 powertrain trans and t case, that would be different...almost justifiable.
fitment would be harder then the 5.0 or ls my magnitudes.
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
87 ranger supercab 4x4 fm145 swap/one piece driveshaft swap, Angry StRanger 2.9 Liter Forum 1 04-17-2017 10:13 AM
Dan's Definitive 1998 2wd V-8 swap (Coil sprung/Expo swap) dasfinc V-8 Conversion Forums 4 10-01-2010 02:00 PM
death wobble after explorer 8.8 swap and 1 piece shaft swap coolboarder1231 Ranger Axles 4 11-02-2009 11:26 PM
whats the easyest do to swap gears or swap axle 84stealthranger Ranger Axles 9 10-19-2009 12:34 AM
94 Ranger owner, 4.0 swap, explorer axle swap trhull Introduce Yourself 1 12-13-2007 06:23 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
