Advance Adapters Transfer Case Kits
absentminded102
Johnston County, NC
5.0L
Just wondering which kit I need for my 95 extended cab Ranger. Advance Adapters makes 2 different kits for the swap. (50-8404 and 50-8405) One is longer than the other.
mavereq
Concrete, WA
I have to ask: why would you spend so much money to keep a crappy transfercase?
absentminded102
Johnston County, NC
5.0L
Well, because I'd like to have the transfer case in the stock location so I won't have driveshaft issues... That's why I'm asking about part numbers to avoid having to custom make the driveshaft. I'm also considering using the BW 4405 electronic shift case.
Tanders
Even if you get the wrong one just cut an inch of the splines and your shaft will fit. You'll have to fabricate the cross member though. When I was looking for that adaptor they only had one size and said it would work when I called and told them it wasn't the right one.
