Got the diff put back together with new seals.
Also hit the diff with a wire wheel and hit it with clear coat.
Got the diff installed and the axles painted up.
Installing that diff was no easy task. I had to undo one radius arm, remove the coil springs, and jack up the center of the truck.. Problem is the truck has so much flex now accomplishing any of those is not easy. I dropped the truck with no driver coil to re position the jack... My driver frame rail touched the ground haha.
Warrantied RC brake lines come in today and then ill make sure my alignment is correct and start taking measurements to make the DOM steering. I will be taking the knuckles off and milling them to 3/4" on my mill, along with the drop pitman arm.
