Wiper Delay Location
bobaloo
Casco, Michigan
4 Banger
I have a 94 Ranger XL and would like to know if the wiper control is located under the dash or is it all controlled up in the column? I think I found a box that clicks when wipers are turned on but don't want to go through the hassle of removing it if it's not the part. If it is does anyone have a part number?
TIA
Bob
bn6339
The module is located under the dash sort of in the center of the dash with a 9 wire plug attached to it...a couple wire colors to check would be a Yellow/red stripe, dark green, brown/white stripe....hopefully that helps...look at this link: www.fordparts.com. Select the year and model, then go to wiper/washer and select window wiper motor. The wiper motor governor lists for $135.00, gives the Motorcraft part number, and also shows where the module is mounted.
BSG (BN6339)
bobaloo
Casco, Michigan
4 Banger
Thanks! I appreciate your help. Hopefully I can find one cheaper than that.:dunno:
Staff online
Today's birthdays
Shran
April Truck of The Month
