Quick timing question
Lost Bushman
Lexington, SC
When switching from the A4LD to a FM146, what should I adjust my timing to? it's idling high and has a weak top end.
Sent from my Casio G'zOne Commando 4G, it's the John Connor of Smartphones. You cannot kill it...
Using Tapatalk.
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
I don't think the transmission you have should affect the timing. Idle, yeah, probably, but I don't think the timing would need to be adjusted. For the 2.9 it says to adjust timing to 10* BTDC, according to my sticker under the hood (90 2.9 with manual tranny).
Lost Bushman
Lexington, SC
This is from the tech article...
"There are a few follow-up things you'll want to do. First and foremost, re-time the engine. The timing is different between automatic and manual."
Is this inaccurate?
