how bout this lift
b2murdered
ford
on a 87 b2
what do you guys think about:
2" shackles
explorer front springs and a 3inch body lift with 33s?
RangerBoy94
24
Northern California
360CDI
Honestly body lifts look like crap. And your not going to gain any lift up front with explorer coil springs. I'd save up and buy a James duff stage 1 3 inch lift kit with 2 inch coil spacers and then run 33's it only runs at like 550 with shocks and they have really good shocks. But thats just my opinion.
Loveland CO
2.3L 4Cyl, 2.9 EFI V6
Im buying a procomp 2inch suspension on friday off of ebay for 90 bucks its coil spacers in the front add a leafs in the back.. It seems like an easier lift and better quality. Ive thought about the shackles and explorer springs too. Best of luck to you whatever you do!
b2murdered
ford
well i read somewhere on here tht exploder coils would give a two inch lift idk tho
b2murdered
ford
on tht procomp 2in lift what does it change on the back?
RangerBoy94
24
Northern California
360CDI
You might be confusing the coil springs with the leaf springs. Explorer leaf springs for your rear axle will lift you truck 2 inches in the back. The front coils are the same as a rangers. I believe you can get some coils from a f150 and that will lift it 2 inches but i wouldnt go that route your ride would be crap because the coils are way to stiff.
b2murdered
ford
what bout 2in coil spacers in the front and the shackles on the leaf springs?
Loveland CO
The Procomp rear lift is an add a leaf. You take your leafs off and take them apart put an extra leaf spring in the middle bolt it back up.
RangerBoy94
24
Northern California
360CDI
If you do coil spacers and shackles you will only be able to clear 31's
b2murdered
ford
do the add a leafs really lift the rear 2inches tho?
ive heard of ppl using drop blocks to lift the rear what do u think about tht?
b2murdered
ford
do u think with the coil spacers and the shackles in the rear and a 3in body could clear 33s?
Loveland CO
I was looking at the blocks as well.. The add a leafs are supposed to be better ride quality from what I hear! If you did the shackles, spacers and a 3" Body you should be able to easily fit 33s!
azbronco2
Payson Arizona
2.9L
just go with the 4" kit in my opinion don't waste your time putting all that stuff together the lift companys do a good job of r&d
b2murdered
ford
the james duff is so exspensive tho for me right now
Staff online
Shran
April Truck of The Month
