Leveling Kit and camber
17
mississippi
v6 3.0
So this may be better suited for a different section but here it goes.
I'm doing the ball joints in a couple weeks and thought i'd take the opportunity to throw in some leveling coils while im in there.
The rough country coils are ~$100 on ebay and the adjustable camber bushings arent too expensive but I want to make sure i'm getting the right ones.
According to the tech articles they're pretty easy to install but what p/n's do i need?
http://www.therangerstation.com/tech_library/Alignment.shtml
The Moog K8986 bushings go from +- 2 1/4 degrees but is that enough?
any direction would help. I read through the sticky but It wasnt too clear for the 2wd's.
Haywire6000
Lewiston Maine
1997
2.3 Turbo Four Plug Head
What you need to do it install the coils then bring it in to the alignment shop and have them tell you what you need for camber bushings. I usually max out the camber bushing in negative camber before I bring it it( That way if you still don't have enough camber right off the bat you know you need bushings)
Kirby N.
March Truck of The Month
