- Sep 20, 2009
- Reaction score
- 3,613
- Location
- Dillsburg PA
- Make / Model
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- Manual
- 2WD / 4WD
- 4WD
- Tire Size
- 31X10.50X15
Ok, I will try to explain the relevant parts of this diagram. The section you need to worry about for starting the car pretty much runs down the left hand third of the page. Also, the page I linked is for 89+, which is arranged a tiny bit different than the 86 you are working on. The big difference is that instead of having a fuse block the power on your yellow wire will come from the stack of wires on the starter relay through a fused link.
Ford wiring diagrams generally follow the arrangement of power flows into the page at the top, and run through their loads to ground at the bottom of the page. That isn't really relevant to reading them, just helps finding things.
Your big yellow wire is connected directly to the positive battery cable on one end. The other attaches to the EEC power relay by a pin with two wires coming out of it. The second wire goes to the computer. That wire powers the "gate" of the relay. The piece that moves to close the circuit and power the load. On the other side of the gate should be a dark blue wire that turns red somewhere. It feeds power to two other pins on the computer and the fuel pump relay's coil. The computer then grounds the coil of the fuel pump relay to close it.
Power the the EEC relay's coil comes from a red/green wire that is switched on by the key. Then it looks like the coil should ground through your black and green wire. This is per my 87 wiring book. It looks like Ford may have changed some wire colors. So the black/white wire in the diagram I linked should be your black/green wire.
I am starting to think that your EEC relay has in fact been remove for some reason, as your first picture would seem to show the four wires going to it cut off. This would also mean you seem to be missing a yellow wire somewhere.
