Help with 84 2.3 vacuum lines
Boise Id
2.3
Hi all,
My son and I have rebuilt an 1984 ranger w/2.3 carburetor motor and we need some pictures of how all the vacuum lines hook up and where. We are missing the Tag that is on the core support. Dealer can't help and all the books at the Library don't show actual picture's, just diagram's with abbreviations, next to impossible to follow??
can anyone help us with some pictures.
thanks
Tim
Boise Id
2.3
Really after 3 day's no help??? there has to be somone with an 84 carbed motor out there???????:icon_confused:
kimcrwbr1
46
maplevalley WA
ford
2.8l
Is that the feedback carb and are you running with the TFI ignition. The guys here will know better you just need tyo be a little patient. Do you need to pass emissions if not you can eliminate most of the vacuum crap and go with a duraspark ignition with a vacuum advance. How many wires are comeing out the distributor?
Boise Id
2.3
Thanks for the reply..
Yes I have to pass emission..
Yes feed back carb
3 wires out of Dizzy
Not sure about the TFI ignition it looks like a regular Dura spark set up with the little blue tab spark box.
The Air pump is gone so we are going to hook up a elect. pump from a cavelear and hopes they pass it.
thanks
tim
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
Does this help?
Boise Id
2.3
Thanks BlackBII but I've got that diagram ... doesn't help when you don't know what all the abbveation stand for or what they are and its not diragramed like the motor is set up or colored coded.
Thats why I need some pictures please.
I'm think maybe I can just hook them up to anything so they look hooked up all well have vacuum and hope it passes.
thanks
tim
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
A/CL DV - Air Cleaner Diverter Valve
A/CL BI MET - Air Cleaner BiMetallic valve
ACV - Air Control Valve
MAN VAC - Manifold Vacuum
EXH HCV - Exhaust Heat Control Valve
PCV - Positive Crankcase Ventilation
SV CBV - Solenoid Valve Carborator Bowl Vent
TVV - Thermal Vacuum Valve
LCV - EGR Load Control Valve
VDV - Vacuum Diverter Valve
HICV - Hot Idle Control Valve
IVV - Thermactor Idle Vacuum Valve
TVS - Throttle Valve Solenoid (aka SolePot, Dashpot)
VCV - Vacuum Control Valve
HEAT VLV INT - Heat Valve Intake
TK - Throttle Kicker
FLTR - uuuuuuhhh... "Filter"
VRDV - Distributor Vacuum Retard Delay Valve
AIR BPV - Air ByPass Valve (aka Thermactor Air Bypass = TAB)
BV - Bowl Vent
S - Spark port
ACT - not sure, but on EFIs it means Air Charge Temperature sensor
SV CBV = Carborator Fuel Bowl Solenoid Vent Valve
LCV = EGR Load Control (WOT =Wide Open Throttle) Valve
HICV = Hot Idle Control Valve
IVV = Thermactor Idle Vacuum Valve
VRDV = Vacuum Delay Valve (VDV, VRDV, DV-TW)
(VDV = Vacuum Delay Valve)
(VRDV = Distributor Retard Delay Valve)
(DV-TW = Two Way Delay Valve)
HEAT VLV INT = Heat Vacuum Control Valve Intake, (next to carb)
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
Another
A/CL: Located in the air cleaner
A/CL DV: Air Cleaner Diverter Valve
A/CL BI MET: Air Cleaner Bi-Metallic Valve
A/CL CWM: Air Cleaner Cold Weather Modulator
ACT: Air Charge Temperature Sensor, prior to 1992
ACTS: Air Cleaner Temperature Sensor
ACV: Air Control Valve
AIR: Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for.
AIR BPV: AIR BPV is the AIR Bypass (AIRB) Valve; also called the TAB (Thermactor Air Bypass) Valve
BV: Bowl Vent (on top of the float tanks)
CARB: Carburetor
CBD: Closed Bowl Distributor
CPRV: Canister Purge Valve
DIST: Distributor
DPFE: Differential Pressure Feedback
DV-TW:Two Way Delay Valve
EFCA: Electronic Fuel Control Assembly/ (Fuel Pressure Regulator (FPR)
EGR: Exhaust Gas Recirculation
EGRC/EGRV: EGR Vent/EGR Control
EXH HCV: Exhaust Heat Control Valve
EVP: EGR Valve Position
EGR: Valve Position
EVR: EGR Vacuum Regulator; also called EGR Vacuum Solenoid
FLTR: Filter
FPR: Fuel Pressure Regulator (check vacuum line)
HEAT VLV INT: Heat Vacuum Control Valve Intake, (next to carb)
HICV: Hot Idle Control Valve
IAT: Intake Air Temperature Sensor (Air Charge Temperature (ACT), prior to 1992
IVV: Thermactor Idle Vacuum Valve
LCV: EGR Load Control
MAN VAC: Manifold vacuum-Vacuum source; usually ref. to as Vacuum Tree atop intake manifold]
MAP: Manifold Absolute Pressure
PCV: Positive Crankcase Ventilation
PURGE: Vapor Canister Purge Valve
PV: Ported Vacuum
PVS: Ported Vacuum Switch (PVS) Valve
S: Spark port
SA-FV: Separator Assembly Fuel/Vacuum
SOLV: Thermactor Solenoid Valve
SV CBV: Carborator Fuel Bowl Solenoid Vent Valve
TCAC: Thermostatically Controlled Air Cleaner
TCP: Temperature Compensated Accelerator Pump
TK: Throttle Kicker
TVS: Throttle Valve Solenoid (aka Solepot, Dashpot)
or
TVS: Temperature Vacuum Switch
TVV: Thermal Vacuum Valve
or, TVV: Thermostatic Vacuum Valve (aka Ported Vacuum Switches; Thermal Vacuum Valve)
VAC: Vacuum
VCKV: Vacuum Check Valve
VCV: Vacuum Control Valve
VDV: Vacuum Delay Valve
V CK V or VCV: Vacuum Check Valve
VOTM: Vacuum Operated Throttle Modulator
VRDV: Distributor Vacuum Delay Valve (VDV, VRDV, DV-TW)
VRDV: Vacuum Delay Valve (VDV, VRDV, DV-TW)
VRESER: Vacuum Reservoir (coffee can style in earlier years; replaced by plastic style)
VRESV REST: on earlier years such as SEABRONC's 83 is a Vacuum Restictor/delay valve, it delays vacuum for a certain amount of time
VRV: Vacuum Regulator Valve
WOT: Wide Open Throttle Valve
Boise Id
2.3
:icon_surprised: WoW BlackBII.. thanks for all that typing...:beer: Really sorry, but I still don't know what all those valves look like.. (Old Red neck, Old School of show me..) :D
Thanks again BlackBII..
tim
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
Google is your friend. I'm sure you can find pics of each component if you look hard enough.
Boise Id
2.3
:icon_cheers: :icon_cheers:
DOUBLE Thanks a bunch BlackBII.. that all worked
tim
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS Banner 2012-2015
GMRS Radio License
8,706
Nocona, Texas
Engine Type
4.0 / 2.3 Ecoboost
2WD / 4WD
6-inches
33x12.50x15
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Where was that when I had my original carb??? That was probably the most informative post I've read in 10 years on TRS...
Rep to BBII~
Shran
April Truck of The Month
