Steering
shadow88
CLOQUET MN
FORD
Any one else's fa600 look like this?
forgey4x4
Washington
2.9l both
Definitely custom
ab_slack
12
New Joisey
2.9L
Looks like a custom non stock pitman arm there. Looks extended to come down lower. Vehicle lifted?
shadow88
CLOQUET MN
FORD
Yes it's lifted, I'm Asking if anyone else who's using the fa600 drop pitman arm, if there drag link and tie rod are touching like that,
4
Oneida, Wisconsin
Mazda
3.0L
that is not right. turning to the passenger side looks impossible.
shadow88
CLOQUET MN
FORD
When I turn I get a gab between the arm and the tie rod end, the only time it touches is when it's straight,
shadow88
CLOQUET MN
FORD
If some people with 4" lifts could post pics of what they have, that would be great!
shadow88
CLOQUET MN
FORD
I can't be the only guy running a fa600 arm with a 4" lift?
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I've seen a small number of reports over the years of the tierods hitting (the FA600 arm positions the linkage about an inch or so closer toward the axle).
It seems if having mismatched brand draglink & tierod can aggravate the issue of them hitting (having one side OEM, and the other Moog, for example).
My suggestion is if your tierods are in good shape (you don't want to replace them), take your driverside tierod and bend it's curve back an additional 1/8" to 1/4" or so using a press so it will clear the pitman arm TRE. This shouldn't weaken it by any significant amount.
1RangerNut
Central,IL
2.9L
shadow88
CLOQUET MN
FORD
So before I decided to try and bend my tie rod I wanted to address some other issues I've been having with my bronco, after I had it aligned it just didn't seem right so I wanted to add some more caster, since they told me it was at 2.3 and 3.2, so after adding a little more caster, look what happened
shadow88
CLOQUET MN
FORD
Not much gap but it's not rubbing any more!
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Good deal then. Moving the knuckle that slight bit is all it took.
shadow88
CLOQUET MN
FORD
I still don't have much return to center as I'd like, but I'm getting closer
shadow88
CLOQUET MN
FORD
Any suggestions? When I turn left it has some return to center, but there's even less when I turn right, I'm maxed out on caster for the right side
