Replacing Body Mount, Question
thutton
Port Coquitlam, BC CANADA
Hello,
So my 90 Ranger's body mounts have disintegrated and are in need of replacing. I got a quote from Ford and well the cost is kinda outrages... 200-300 bucks for some rubber...
My question is anyone have experience or opinions on polyurethane body mounts such as:
http://www.suspensionconnection.com/cgi-bin/suscon/6-106.html
or if you have other places you'd recommend please let me know.
Thanks
ozziemo27
June 2010 OTOTM Winner
18
Michigan
4.0 & 2.3
I found a couple threads that have the information you need using the search function. Just search "polyurethane body mounts"
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
I replaced the rubber body isolation mounts with polyurethane ones made by Daystar on my '90 Ranger. I might have bought them through Summit or Jegs, can't recall, it was a couple years ago. I think they're just fine and would do it again. I bought a whole body mount and chassis kit for a little over $100 if I remember correctly
thutton
as per the previous post I was checking out the other post on the topic and everyone is stating the hardware is not included... if this just means the bolts im fine, I bought a replacment set for my 3" body lift
does the kit you bought contain the metal inserts or whatever the other required hardware (except bolts)
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
99% of the time when people refer to "hardware" it's nuts and bolts, however i would not classify the "nut" on the body mounts, as hardware, as it's not a normal hardware store item...
i would imagine they would include the metal inserts, the picture/description should show the difference
and for the record, poly bushings are better (imo) than rubber
v-8power
31
Huntington, In.
It read (12 BUSHINGS ONLY) it the OP link. So i would say that is all your going to get. No metal inserts or bolts and nuts.
--weezl--
Law Enforcement
182
hell
i missed the link on the first pass... yeah totally agree, that's just the polyurethane parts, no metal
CountryBoy78
Rice Lake,WI
So where do you get the steel inserts at?
I been wanting to swap out mine in the 94 Ex but only have found the poly bushings and maybe install a 3 inch body lift.
t0x1k
9
Somerdale, NJ
3.slo
I've been running poly for almost a year now. The hardware was rotted, so all I did was use large fender washers on the outside of the bushings. Runs fine. It's a little rough cause they're poly.
CountryBoy78
Rice Lake,WI
Good idea thanks.... was a little early when I first posted...wasn't thinking right:icon_confused:
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Look into James Duff. That is where I got my Poly mounts for my 92. I had to make my own steel inserts with some galvanized pipe.
CountryBoy78
Rice Lake,WI
Ok just was on James Duff. Do they have body bushings for a 94 Explorer or will ones for the ranger or B2 work?
I suppose the count of bushings would be different than my Explorer.......
superds
80
ND
Ford Bronco II
My Daystar kit included metal molded into the polyurethane bushings. My bottom retaining nuts were rotted so I replaced them with a grade 10.9 (probably higher grade than necessary but it's what the hardware store had for that size) nut welded to a fender washer to make a setup comparable to the stock setup.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
The best I can tell you is call them. They will help you or atleast point you in the right direction. I called them when I did my 92 and they were very helpful and knowledgable too.
r1hatman
4
Knoxville, TN
2.8
