Help: duraspark conversion
Jutter
Kona, Hi
2.8
I have done the duraspark conversion to my 1984 2.8L BII. I followed the tech artical provided in the tech area. I installed every thing and attempted to start the truck up but nothing. It cranks but doesn't run, so I pulled a plug to see if I was getting spark. At first there was spark while cranking then I realized that my plug wires were out of order. I corrected this but still nothing. So pulled a plug again and noticed that now there is only spark when I let off the key from cranking. The original wiring was pretty bad and the p.o. had in stalled a resistor for tfi coil. So for now a couple questions:
#1) should I have installed the resistor for the duraspark coil? The new coil didn't come with one and I didn't see anything in the write up about it or maybe I have over looked it.
#2) So now that I'm only getting spark in the run position, does this mean my duraspark modual is fried? I tested for voltage at the connector in the truck and found that there is voltage coming in when cranking and in the run position.
Any thoughts / advise would be appricated.
PetesPonies
25
east coast
Ranger
2.3l
I did the Duraspark conversion on my '84 a few years ago. When I switched engines ( V8 ) i kept it. It has worked great. But I used a GM HEI module along with the Duraspark distributor. $19 and works better than the stock box IMO.
Spede Demn
Irricana AB
'85
2.8L
Kind of sounds like you might just be missing a wire from the ignition switch to the coil, or possibly the wrong wire maybe. Not much help really but I did the duraspark conversion on my 85 B2 using the TRS tech article and never had a problem with it.
Jutter
Kona, Hi
2.8
I think I'm gunna try the hei module. Can I use the power wire from the duraspark connector to power the hei module?
Spede Demn
Irricana AB
'85
2.8L
Did you buy all new electronics or get used stuff? I bought all new and did the conversion over xmas just 3 months ago.
I have my B2 inside the shop at work every evening, could go over it in more detail via txt message if you want?
Im old and forgetful but I think there was two wires needed to be spliced together to get power to the coil... is that what you have?
kimcrwbr1
46
maplevalley WA
ford
2.8l
Have you removed the complete computer wiring? the only wires you need to cut from the 8 wire connector by the coil are for the computer hopefull you cut them long for future use? I just connected the two wire connector the red and white are backwards but still correct. I used the computer power wire for the coil and just run athe green wire from the module to the coil neg. I found a distributor harness from a 84 4 cyl and was plug and play. basically the only two wires spliced are green to coil pneg and key on hot to coil pos. Do you have the distributor in the correct position. One trick to get it running is shine the timing light on the timing marks and just find the wire that gets close to TDC. Put hat wire on the #1 plug and set the firing order from there. If that dont work rotate the wires 180 degrees and try again 1-4-2-5-3-6
kimcrwbr1
46
maplevalley WA
ford
2.8l
I am using the stock TFI coil without resistor.
Spede Demn
Irricana AB
'85
2.8L
I dont 'think' that coil will work.. but I didnt try it.
PetesPonies
25
east coast
Ranger
2.3l
I use the stock TFI coil with the GM HEI module and it is fine.
kimcrwbr1
46
maplevalley WA
ford
2.8l
Yea I was messing with the vacuum line for my auto tranny it is right next to the dizzy when the engine was running and I knocked a plug wire up on the cap it didnt shock my hand but I was leaning close to the fender. Put it this way I now know what it means to get it knocked in the dirt. The TFI coil really bites.
PetesPonies
25
east coast
Ranger
2.3l
You probably only got small amount too . . as a coil will discharge whenever it can. Conditions outside a cylinder are easier an arc to happen, so you probably didn't get it's full charge :)
Spede Demn
Irricana AB
'85
2.8L
So Im confused... are you using the original square coil connected with the electronic ign module and with a vacumn distributer? and still have the computer hooked up? if so why?
I did everything exactly as the TRS tech article and threw away everything else, no computer, no polution control, nothing. I have a distributer, a coil w/resistor, and an ignition module.
kimcrwbr1
46
maplevalley WA
ford
2.8l
All the computer wires are gone at the grey 8 wire connector by the coil there are a couple hots use the key on hot for the coil. the other wires ar for the guage senders and alternator to regulator. You only need to cut a couple wires from that connector to compleetely remove the computer harness. I hope you cut them long?
Jutter
Kona, Hi
2.8
I picked up an hei module to try if I can't get the duraspark box to work.
I think the problem I'm having is that there is no power to the coil when cranking. I need to find a way to power the coil when cranking and in the run position. I have a brown with pink wire that is where the write up says to power the coil. So I put a test light on it when cranking and there is power there but no power when the key is returned to the run position.
Even if I do end up using the hei module how do I power it during cranking and in the run position?
Spede Demn
Irricana AB
'85
2.8L
In the plug from the ignition switch you should be able to find a wire that is hot only when the ignition is in the 'cranking' position, and another one that is hot only when the ignition is in the 'on' position... splice them together and run to the + coil.
Staff online
Today's birthdays
Shran
April Truck of The Month
