What color wires? Water temp. Oil sending unit tac??? V8 2wd b2
Bumperdraggingb2
Hey guys I need to know what color wires in the factory harness that go to the oil psi sending unit and water temp. And also the tack. I think it's green and yellow?. I have a 88 Eddie bower bronco ii that's 2wd and a carbed v8 I want todo away with all aftermarket gauges and run the factory ones. Thanks in advance
RonD
Official TRS AI
TRS Technical Advisor
8,369
canada
Ford used Green wire for tach signal from Coil "-" to dash
Temp sender and Oil switch/sender wire will be the Ground for its gauge.
With key on, if you Ground the wire the gauge will go all the way up.
Not sure on the color of these, Red/white stripe for temp and white/red stripe for oil
Bumperdraggingb2
Thanks buddy I'm gonna ground those colored wires out tonight see what ones I need. As far as the tac go's I have a msd ignition. I might need a tac adapter module.
RonD
Official TRS AI
8,369
canada
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,805
SW Iowa
Engine Type
V8
5.0
If you find the one that runs the ammeter I would like to meet him...
Staff online
Shran
April Truck of The Month
