a sad sad day
1984broncoduce
olive branch mississippi
ford
2.8
i have been working on my b2 and found a crack in the block, and i don't have the money to do a 302 swap or get a new block, so I'm parting to out then scraping it :sad: some day il get another
BabyBronco89
Solid Axle Swap
2
GR Michigan
95' 4.0 OHV
sounds like its time for a 4.0!!!!
1984broncoduce
ford
2.8
my budget at the moment is very small, and in a few weeks I'm buying my grandpas 1996 f150
jhammel85
Guest
Man, I'm sorry to hear it..I hate to hear about anything going to the JY..especially a Bronco II.
If you have the time, why not put in a junkyard motor? It's cheaper than a new car and you know the truck top to bottom. Even so..What about just buying another Bronco?
1984broncoduce
ford
2.8
Because I'm only going to pay 200 for the f150, but I say in 2 years il end up getting another b2, but this time a 2.9 with a 5 speed
B2 Addict
TRS Banner 2012-2015
9
Lavergne, TN
Engine Type
V8
5.0
2WD / 4WD
Solid Axle Swap 4x4
37x12.50-17
Nooooooo, don't scrap it!!!!! What shape is it in other than the block and would you consider selling the whole truck? Got any pics?
:icon_cheers:
B2
4.0B2
151
Walls, MS
4.0 v6
personally, unless you NEED the money now...don't scrap it. build it slowly while driving the f150. buy a 4.0/md05/8.8/d35.. build it slowly. junkyard builds can be cheap.
iron butt
S.E. Pa
2.9
To bad your so far away, I'm in the process of pulling a 2.9 out of a 90, it has issues, but a good block. You'd be welcome to it, just haul it away, it does run. Or else it just gets stashed,tripped over and moved around. I just got way to much crap that I've been hanging on to.
BabyBronco89
Solid Axle Swap
2
GR Michigan
95' 4.0 OHV
i only had 200$ into my 4.0 b2 all you really need is a running engine n wiring harness from the right year explorer or ranger and its a project you can accomplish in 4-5 days workin at it yourself or a weekend with some buddies
4.0 engines and parts are a lot easier to find then 2.9 stuff
its not really that bad
i did it instead of putting another 2.9 in my b2 i had way too many problems with the 2.9 even after completely rebuilding it
just a lil motivation
just dont send it to the crusher
shane96ranger
221
Utah
Ford F150-Stang
Engine Type
V8
4.6 Triton / 5.0
Wise words right here.
1984broncoduce
ford
2.8
they all sound like good ideas, but i need the money at the moment, if anyone needs any parts PM me
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Same deal here. I have a stripped block on the stand right now.
4.0B2
151
Walls, MS
4.0 v6
I just realized you're in OB. I live in walls. I'm not to far out. I wish I still had my 2.9 I'd donate it to the cause if I did. Wish I could be more help since I'm so close.
What would you want for the b2? As it sits. What's the specs on it? Myself or a buddy might be interested.
What color is the interior? Does it have the overhead 4x4 console?
Have you thought junkyard motor? Pull a part up on farrisview should have some motors maybe...
4.0B2
151
Walls, MS
4.0 v6
its a 84 auto, blue interior and its a floor shift 4x4
i might need a couple interior pieces...and the shifter setup if its an auto w/ manual t/case. i eventually wanna find a 1354m setup. what part of OB are you in?
i'd much rather see you keep it and fix it... but if it does come down to you scrapping it i'd like to look at it and talk about some parts/entire thing.
Staff online
Shran
April Truck of The Month
